Received invalid response: 65 while testing DB connection
I am testing a postgresDB connection.
Host: IP of my hosting provider (used you IP to authorize the remote connection)
User/PWD as per my db
SSL β†’ disabled
FAILS with error: received invalid response: 65
what does this means?
tyvm
  • cloud
it’s not applicable. I am testing your cloud version
it was an issue connected to my provider which allows only MYSQL remote connection, not Postgres. trying to port in MySQL the node.
