Reddit node: “Get many subreddits” returns Forbidden (other flow can post successfully)
Hi,
I’m trying to use the Reddit node Subreddit → Get Many, but I keep getting the error: Forbidden – perhaps check your credentials?.
The strange part is that I already have another flow using the same credentials, and it can post to Reddit without any problems.
Expected behavior:
Return a list of subreddits (or my subscriptions) so I can use them in the workflow.
Actual behavior:
The node returns Forbidden and even shows some HTML/CSS output (see screenshot).
Screenshots:
– attached (“Get many subreddits” node and error output).
The same problem, this node does not require verification, so I am confused
Hii @Heeey_Yooou Hope You Are Well ,
I Have Try To Fix The Trouble You Are Getting ,
I Think We Can Not Get Many Subreddits Of Our Subscriptions ,
Other Than We Have To Give Parameter To Subreddit Like [News , Food etc..]
I Am Sharing A Screenshot For This .
Try Giving Any Keyword You Like .
@liam Any updates on this ,we are getting the same error.
Got the same error. There’s no way to put credentials.
