About The Issue info
I am trying to automate posting on Reddit using n8n, but it is not working for some reason.
Error message?
No output data returned
n8n stops executing the workflow when a node has no output data. You can change this default behaviour via Settings > “Always Output Data”.
n8n setup
- n8n version: 0.209.4
- Database: SQLite
- Running n8n with the execution process: own
- Running n8n via: Docker
Can anyone help me troubleshoot this issue? Thank you in advance for your help.
