I am running a workflow with Redis get, set and memory, but when I try to run the memory at an AI agent, it recognizes the chat_id, but returns and “undefined” problem, so I don’t know what to do right now.
Can you do screenshot of other redis config node also? Is it similar? Meanwhile, can you test with just replacing key with {{ “554499855916@s.whatsapp.net” }}
Additionally, I have changed the Redis Memory key, and apparently, it worked; however, I need to run further tests to confirm if this is indeed the solution. It may be causing confusion between Redis push and get memory, and the Redis AI Memory.
