Hi, good afternoon.
I would like to know how I can reference the columns for insertion into the table.
I used to be able to do it by dragging, but unfortunately I am not able to anymore.
n8n version: 1.33.1
Database (default: SQLite): MySQL
Running n8n via (Docker, npm, n8n cloud, desktop app): docker
Operating system: win 10.
I did it this way, but this way the rows 0111301 and Rice cultivation are not inserted.
barn4k
April 1, 2024, 9:43pm
3
hello @miguelraatz
You should disable the Header Row switch and then you will be able to operate the rows
If you remove that option, it will count as enabled (by default).
system
Closed
April 9, 2024, 11:29am
5
