Refreshing OAuth2 credentials for Power BI, expiring token
  • I have setup a OAuth2 credentials to connect to Power BI service
  • I have created and provided the necessary permission to a registered app in Azure AD
  • When creating the OAuth2 credential, I have provided the necessary scope for connecting to Power BI and included access_type=offline in the Auth URI Query Parameter
  • Once the credentials are initially connected, the workflow works fine
  • However, once the token expires, the token does not refresh
  • 403 - "{\"error\":{\"code\":\"TokenExpired\",\"message\":\"Access token has expired, resubmit with a new access token\"}}"
:light_bulb: Double-click a node to see its settings, or paste this workflow’s code into n8n to import it
Credential setup
  • n8n version: Version 2.2.4
  • Operating system: MacOS
I’d blur out the call-back URL :wink:
As for the token. When I’m workign with Business Central I get a valid-time in seconds as part of the response. If the token expires, or is close to expiring, it’s relatively easy to renew it using a generic HTTP request:
Powershell example (may work differently if you need a different grant type):
access token
$body = @{
grant_type=“client_credentials”
scope=$scope
client_id=$ClientID
client_secret=$ClientSecret
$oauth = Invoke-RestMethod -Method Post -Uri https://tokenurlfrommicrosoft -Body $body -ContentType “application/x-www-form-urlencoded”
Whoops, thanks @Galactic_pawns - more blurring applied!
I had been trying the HTTP request way for a while without success, however today it’s worked!
Appreciate your help.
