When I am in the editor, and switch to executions view, I just get the spinning ring of orange circles in the view frame. Instead of the actual execution selected in the execution list on the left.
I turned on inspection to see what console errors there were. And this one stood out to me:
Refused to display ‘https://n8n.bandofcoders.com/’ in a frame because it set ‘X-Frame-Options’ to ‘deny’.
The x-frame line seems to maybe be it, but I am open to interpretation. (FULL CONSOLE OUTPUT AT THE END)
Any ideas on why I can’t seem to load executions? This is not tied to this single workflow, but to all execution views across all workflows.
Might it have something to do with my worker / main setup?
WORKFLOW:
- n8n version: Version 1.24.1
- Database (default: SQLite): postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): queue? (I think see docker compose file)
- Running n8n via (Docker, npm, n8n cloud, desktop app): running via docker compose
- Operating system: ubuntu lxc on proxmox
Docker-Compose File:
version: ‘3.8’
volumes:
db_storage:
n8n_storage:
redis_storage:
x-shared: &shared
restart: always
image: docker.n8n.io/n8nio/n8n
environment:
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=postgres
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
- DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
- DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
- EXECUTIONS_MODE=queue
- QUEUE_BULL_REDIS_HOST=redis
- QUEUE_HEALTH_CHECK_ACTIVE=true
# Additions for URI fixes
- N8N_HOST
- WEBHOOK_URL
- WEBHOOK_TUNNEL_URL
- N8N_EDITOR_BASE_URL
- N8N_PROTOCOL
- VUE_APP_URL_BASE_API
# Additions for production env
- GENERIC_TIMEZONE
- NODE_ENV=production
- NODE_OPTIONS=–max-old-space-size=2048
links:
- postgres
- redis
volumes:
- ./n8n_storage:/home/node/.n8n
- ./local-files:/files
- ./.ssh/:/home/node/.ssh/
depends_on:
redis:
condition: service_healthy
postgres:
services:
postgres:
image: postgres:11
restart: always
environment:
- POSTGRES_USER
- POSTGRES_PASSWORD
- POSTGRES_DB
- POSTGRES_NON_ROOT_USER
- POSTGRES_NON_ROOT_PASSWORD
- POSTGRES_SHARED_BUFFERS=2GB
- POSTGRES_MAINTENANCE_WORK_MEM=1GB
- POSTGRES_EFFECTIVE_CACHE_SIZE=2GB
- POSTGRES_WORK_MEM=64MB
- POSTGRES_MAX_PARALLEL_WORKERS=10
- POSTGRES_MAX_PARALLEL_WORKERS_PER_GATHER=5
volumes:
- ./db_storage:/var/lib/postgresql/data
- ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
healthcheck:
test: [‘CMD-SHELL’, ‘pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}’]
interval: 5s
timeout: 5s
retries: 10
redis:
image: redis:6-alpine
restart: always
volumes:
- ./redis_storage:/data
healthcheck:
test: [‘CMD’, ‘redis-cli’, ‘ping’]
interval: 5s
timeout: 5s
retries: 10
n8n:
<<: *shared
ports:
- 5678:5678
n8n-worker:
<<: *shared
command: worker
depends_on:
- n8n
FULL CONSOLE OUTPUT:
vendor-2CfOYFi2.js:1 [Violation] Added non-passive event listener to a scroll-blocking ‘touchstart’ event. Consider marking event handler as ‘passive’ to make the page more responsive. See Chrome Platform Status
Je @ vendor-2CfOYFi2.js:1
Da @ vendor-2CfOYFi2.js:1
Wa @ vendor-2CfOYFi2.js:1
B @ vendor-2CfOYFi2.js:1
S @ vendor-2CfOYFi2.js:1
A @ vendor-2CfOYFi2.js:1
O @ vendor-2CfOYFi2.js:1
run @ vendor-2CfOYFi2.js:1
G.d.update @ vendor-2CfOYFi2.js:1
G @ vendor-2CfOYFi2.js:1
$ @ vendor-2CfOYFi2.js:1
Y @ vendor-2CfOYFi2.js:1
x @ vendor-2CfOYFi2.js:1
L @ vendor-2CfOYFi2.js:1
j @ vendor-2CfOYFi2.js:1
process @ vendor-2CfOYFi2.js:1
chrome-error://chromewebdata/:1 Refused to display ‘https://n8n.bandofcoders.com/’ in a frame because it set ‘X-Frame-Options’ to ‘deny’.
[Violation] ‘setInterval’ handler took 111ms
62610:1 Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
