Removing Docker Images of Previous n8n Versions
I discovered that my Docker configuration had numerous old and very large dangling n8n images which I just pruned and cleaned up ~31 GB in space!
Can I also remove Docker images of previous n8n versions without harm?
  • n8n version: 1.26.0
In my experience - you can remove them. You should keep in mind your own situation - meaning - if you update / upgrade and delete the “old” version - you would need to redownload / build it in case you would like to go back.
