Retrieving body from a POST multipart/form-data request
Hi everyone, first of all, I’d like to say I’m really pleased to join the n8n community : I discovered n8n through SeaTable, and I really love it, thanks a lot for all this work and for maintaining a community version :+1: !!
Here is my problem now : I’m trying to retrieve some data sent to my workflow from an internet page through a webhook trigger. I didn’t encounter any problem while sending simple json data via a POST request with an application/json Content-Type (see bellow).
While trying to send files however, I changed my Content-Type to multipart/form-data and I don’t encounter any error (I get a 200 response-code) but I can’t get any data (my request’s body is always empty).
I have an html page with simple text and email inputs, and one select (I dropped the file upload for now as the problem is already present without that). As you can see bellow, I can send my request with both Content-Types : with the sendMsg() function for application/json Content-Type, and with the sendMsgFormData() function for multipart/form-data Content-Type.
function sendMsg() {
    let data = {
	text: 'Name : '+document.getElementById('name').value+'<br>Email : '+document.getElementById('email').value+'<br>Message : '+document.getElementById('text').value,
	channel : document.getElementById('channel').selectedOptions[0].value,
	email : document.getElementById('email').value
    fetch("https://vps-25355c52.vps.ovh.net:6231/webhook-test/da4a7645-ccc6-4a0d-a1aa-0dd87460ef6a", {
      method: "POST",
      headers: {'Content-Type': 'application/json'},
      body: JSON.stringify(data)
    }).then(res => {
      console.log("Request complete! response:", res);
function sendFormDataMsg() {
    let data = new FormData();
    data.append('text', 'Name : '+document.getElementById('name').value+'<br>Email : '+document.getElementById('email').value+'<br>Message : '+document.getElementById('text').value);
    data.append('channel', document.getElementById('channel').selectedOptions[0].value);
    data.append('email', document.getElementById('email').value);
      method: "POST",
      headers: {'Content-Type': 'multipart/form-data'},
      body: data
    }).then(res => {
Webhook trigger node (I can’t really call that a workflow :joy: )
> Result for the sendMsg() function (application/json Content-Type) (working well)
Request from Firefox browser
  "text":"Name : John Doe<br>Email : em@il.com<br>Message : lorem ipsum",
  "channel":"opt1",
  "email":"em@il.com"
Response from n8n Webhook trigger
Please note that if I activate the Raw Body option, I can get a binary output
> Result for the sendMsgFormData() function (multipart/form-data Content-Type) (not working)
-----------------------------415566053936813124942139406569
Content-Disposition: form-data; name="text"
Content-Disposition: form-data; name="channel"
opt1
Content-Disposition: form-data; name="email"
em@il.com
-----------------------------415566053936813124942139406569--
Activating or deactivating the Raw Body option doesn’t change anything, I just get the headers…
my n8n setup
  • n8n version: 1.32.2
  • Database (default: SQLite): PostgreSQL
  • n8n EXECUTIONS_PROCESS setting (default: own, main): sorry I didn’t manage to find this piece of info :sob:
  • Operating system: Debian GNU/Linux 12 (bookworm)
I’m sure I missed something pretty simple, but I can’t figure it out, and I browse the forum but found much more information about sending through HTTP POST requests thant about retrieving sent data.
Thanks a lot for your help!
Bests,
Benjamin
Hi everyone,
I’m answering myself : the problem was not related to n8n, but to my HTTP POST request : while specifying myself headers: {'Content-Type': 'multipart/form-data'}, in my fetch request, the headers actually lacks the necessary boundary piece of data.
I deleted the header, which is automatically added, with the boundary, if your data is actually a FormData object. For those who might encounter the same problem, here is my final sendMsg() function:
data.append('myKey', myVal);
// add as much data.append lines as you need depending on the key/value pairs you have to send
// dealing with the files sent (inside <input type="file" id="files" name="files" multiple>)
for (let f=0;f<document.getElementById('files').files.length;f++) {
    data.append('file'+f.toString(), document.getElementById('files').files[f], document.getElementById('files').files[f].name);
// Eventually disable your send button and warn that upload might take some time in an appropriate div
// POST Request (with NO headers defined to ensure the multipart/form-data AND boundary are automatically added)
fetch("https://vps-25355c52.vps.ovh.net:6231/webhook/abedf070-1091-40c7-a7f8-e53a34a0a454", {
  method: "POST",
  body: data
}).then(res => {
  if (res.status == 200) {
      console.log("Success!");
To get the sent files in n8n, you’ll have to activate the Raw Body option of your Webhook trigger node.
Bests,
Benjamin
