Retrieving Clients by Phone number or Order ID's from Vector Store
Thx n8n for this amazing product : )
I’m experiencing issues retrieving phone numbers, order IDs, and names from our Pinecone v store.
O1 advised me to use meta filters with identifier JSON keys to get precise responses from Pinecone, but from what I’ve read, this feature does not exist in n8n.
Basically, this vector space tool/agent is mostly useless for us, as it finds the order/client only 10–20% of the time, no matter how big or small the chunk size or the overlap i set up.
We simply don’t get our questions answered, despite having a clean vector space structure that seem to be well split.
      "pageContent": "; Name: Go*** Guntaka (Kevin; Identifier: +1*******336, gu*********[email protected], 160*****08, ;",
      "metadata": {
        "blobType": "text/plain",
        "createdTime": "2024-08-21T00:46:28.000Z",
        "loc.lines.from": 47,
        "loc.lines.to": 48,
        "recordID": "recYhbg9NdT6UxMlB",
        "source": "Clients"
      "id": "5d10d4de-dbb3-491e-9070-87a74a6b2b21"
please help🥲
  • n8n version: Version 1.71.2
  • Database (default: SQLite): where to lookup?
  • n8n EXECUTIONS_PROCESS setting (default: own, main): no idea what that is
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Railway
Hi @prostor.dd
Thanks for posting here and welcome to the community! :raised_hands:
The Pincecone node does allow for a Metadata Filter:
If you put your identifiers in the metadata column directly, you can reference this in your workflow and the retriever will be able to find the relevant data more accurately :slight_smile:
Hope this helps!
Thank you, overlooked it…
And I have a follow-up question: When a human requests record by by record ID, for example, the AI method does not work… a bit confused how to implement this…
basic name fromAI also does not work, so how shout this be done?
I would actually put that in the system message of the agent, and there you could also provide an example of what the recordID might look like.
We’ve actually just released a pretty cool tutorial on how to use the $fromAI() function in tool nodes. Maybe it can help to clarify some :slight_smile:
Thank you Ria.
But it’s still not working with $fromAI() formula
here is the System Prompt
here is the meta filter:
As soon as I remove $fromAI() and replace it with any static text, the flow runs fine.
here is the console log
logUtil.js:41 [handleError]:: "Converting circular structure to JSON
    --> starting at object with constructor 'Object'
    |     property 'component' -> object with constructor 'Object'
    --- property 'vnode' closes the circle"
