Return a field in my json input as output in a code node
I have a json input that looks something like this:
“headers”: {
//some data
“params”: {},
“query”: {},
“body”: {
// some data,
“employees”: [
“first_name”: “Osarumen”,
“last_name”: “Alohan”,
“position”: “Backend Engineer”
“first_name”: “Bill”,
“last_name”: “Gates”,
“position”: “CEO”
I want to output the array of ‘employees’ from the code node so I can loop over and add them to a database. I’m unable to find a solution that works from the docs and I keep getting errors. Please help
n8n version: 1.12.1
running n8n via: n8n cloud
operating system: windows
Hey @Osas,
Have you tried using the Split Out node on body.employees that will give you something like this.
You can find a test workflow below for this.
Thanks a lot @Jon. This helped. However I noticed that when I attempt to use input from a node not immediately preceding the split out node I get an empty output
Hey @Osas,
Yeah if you are splitting out the data we expect it to be from the node before it, If you wanted to go further back you would need to use a code node and manually write out a bit of code to get the data from the previous node and split it out into items.
