Running localhost
I’m trying to test n8n to see if it works for us, but I do not want to set up and domains or go outside of our internal network at all, but when I try access the webhook at localhost:5678 and I try send something via insomnia it only returns a status 422 and I get nothing in n8n…
Can this run as localhost?
Hey @mika76,
You can run it on your localhost but if you are using docker or a different machine make sure there is a route between you and the container.
Try using the IP instead of localhost and seeing if that helps.
