Hello
I’m trying to get a list of files from Cloudflare R2 via S3 Node. I managed to get the bucket list, but I’m unable to do it with files. Is this normal? How would you do it for CF R2? I also tried via HTTP request, but it doesn’t seem easy or possible. Any suggestions would be appreciated. Thank you.
- n8n version:
- Database (default: SQLite):
- Operating system:
Hi, if the problem is still relevant, check it out
- Have you made the bucket url available public
- Which buckets are subject to the api token rights
A common problem is for s3 endpoints to specify the path to the bucket, but if the rights apply to all buckets, then the endpoint does not need to specify the bucket path via /
