I am trying to build a simple solution that will be able to list/read/download files from S3.
Firstly I tried:
AWS S3 Tool - The tool refuses to see folder that were not created by the console.
the only way to see folders is to go to the console and hit the “create folder” button.
Any that you upload by dragging in a folder or uploading via aws cli or any other method will produce blank. no idea why no idea how to solve this.
So I move to the HTTP node - well, that worked… but when i tried to create a tool with the exact same parameters. I get an error:
"response": "HTTP ERR_INVALID_URL There was an error: \"Invalid URL\""
Ok sure, After I tried everything i could i just decided to give https://www.google.com , also getting the same error… this is broken!
So the last option that I have is to start coding it with boto3 in python or AWS CLI or something which is just ridiculous
what is actually happening here. are the nodes broken, is there some trick that i am not aware of? I am getting to the point where N8N is becoming unusable and I will need to explore other solutions…
Also note that the credentials work, they work in some cases with the nodes (but the data is returned missing) and it works when I try the credentials directly with aws cli (which returns the correct data).
Thanks
- n8n version: 1.80.3
- Database (default: SQLite): SQlite
- n8n EXECUTIONS_PROCESS setting (default: own, main):?
- Running n8n via (Docker, npm, n8n cloud, desktop app): kubernetes in AWS
- Operating system:Linux
