Scaling Geo-Targeted Ad Monitoring with n8n + AI + Proxies
Hey folks,
I wanted to share a setup that’s helped me scale ad monitoring across multiple locations, without building a custom backend or using Selenium scripts that constantly break.
:light_bulb: The Problem
When running or analyzing geo-targeted ads (Google, Facebook, native ads, etc.), we often face these issues:
  • Ads vary by country, city, and even IP reputation
  • You can’t trust VPNs alone — fingerprint and location both matter
  • Capturing visuals or landing pages at scale is tedious
  • Traditional tools get flagged or blocked quickly
:puzzle_piece: The Stack I Use
:white_check_mark: Hidemium:
Creates isolated, fingerprint-safe browser environments per location (mobile/residential IPs, timezone, OS, language, etc.)
:white_check_mark: n8n:
Handles the orchestration — launching flows, retrying errors, and saving screenshots/logs to Airtable or Notion.
:white_check_mark: AI Agents (ChatGPT / Claude):
Used for interpreting dynamic content or interactions — for example:
“Open site, click ad banner if shown, capture screenshot, and log the URL.”
:repeat_button: Example Workflow
  1. Cron Trigger in n8n (every 30 min)
  2. Set parameters (country, ad network, device type)
  3. Trigger Hidemium profile via API (US, iPhone, dark mode, etc.)
  4. AI navigates to publisher page, scrolls, clicks, waits for JS
  5. Take screenshot + extract visible text
  6. Send to Airtable / Webhook / Email
:camera_with_flash: Sample Use Cases
Use Case Description
Native ad verification Check if Taboola/Outbrain is showing your ad in a specific country
Affiliate compliance Make sure landing pages match network guidelines
Competitor monitoring Capture ad variations across multiple geos
A/B testing See how creatives render across devices and IP ranges
:locked_with_key: Bonus: Why Hidemium Helps
  • IP + fingerprint match = low detection rate
  • No need to rotate proxies manually
  • Supports real browser rendering (vs. headless)
  • You can run multiple profiles in parallel (good for scaling)
:handshake: Let’s Connect
Curious if others here are doing something similar.
Happy to share JSON flows or prompt templates if anyone’s interested.
Let me know what tools or tricks you’re using for geo-specific automation!
I’ve been struggling with stable ad scraping across multiple GEOs. Didn’t think of using AI agents for dynamic banner detection — that’s super smart.
Would love to see a sample n8n flow if you’re open to sharing!
I need it, doing a similar exercise @Abert
