Scenario stops after completion of first loop task
Scenario stops at the end of the first loop, and I can’t find a solution for moving on to the second city to be processed.
About n8n
n8n Version 1.49.0
Database (default: SQLite)
n8n EXECUTIONS_PROCESS setting (default: own, main): own
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker compose
Here’s a screenshot of the scenario
I found the solution, the new If node doesn’t work. You have to use the old IF node
Hi @Cedric
thanks for posting you issue and also the solution :raised_hands:
What is the condition that fails on the IF node?
I see you’re checking some true/false statements, did you understand why these are failing?
Hi @giulioandreini,
The true path of the new node does not work. Maybe I’m using it wrong, it would be good if several people could check this problem.
