I’m trying to run Self-hosted AI starter kit (GitHub - n8n-io/self-hosted-ai-starter-kit: The Self-hosted AI Starter Kit is an open-source template that quickly sets up a local AI environment. Curated by n8n, it provides essential tools for creating secure, self-hosted AI workflows.) but I’m getting the following message that wont let N8N start:
Permissions 0644 for n8n settings file /home/node/.n8n/config are too wide. This is ignored for now, but in the future n8n will attempt to change the permissions automatically. To automatically enforce correct permissions now set N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true (recommended), or turn this check off set N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=false.
There was an error initializing DB
connect ECONNREFUSED 10.89.0.79:5432
This is from the logs file:
Error: Database is uninitialized and superuser password is not specified.
You must specify POSTGRES_PASSWORD to a non-empty value for the
superuser. For example, “-e POSTGRES_PASSWORD=password” on “docker run”.
You may also use "POSTGRES_HOST_AUTH_METHOD=trust" to allow all
connections without a password. This is *not* recommended.
See PostgreSQL documentation about "trust":
https://www.postgresql.org/docs/current/auth-trust.html
This is the ps list
If I try to connect to postgres server using the credentials in the .env file it does connect from an external client:
How can I fix this issue?
