Hi guys, I’m trying to use the Send and Wait for Response integration with Slack. However, every time I attempt to send a simple message, I receive the following error: “Slack error response: ‘invalid_blocks’.”
“errorMessage”: “Slack error response: "invalid_blocks"”,
“errorDetails”: {},
“n8nDetails”: {
“nodeName”: “Send and Wait for Response”,
“nodeType”: “n8n-nodes-base.slack”,
“nodeVersion”: 2.3,
“resource”: “message”,
“operation”: “sendAndWait”,
“time”: “5/8/2025, 9:25:36 AM”,
“n8nVersion”: “1.92.1 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“NodeOperationError: Slack error response: "invalid_blocks"”,
" at ExecuteContext.slackApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Slack/V2/GenericFunctions.js:104:11)“,
" at processTicksAndRejections (node:internal/process/task_queues:95:5)”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Slack/V2/SlackV2.node.js:333:7)“,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:689:27)”,
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:923:51",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1259:20"
- n8n version: 1.92.1
Preformatted text
