Hello everyone,
I’m trying to send some results to InfluxDB, since there is no node available for it I tried using the HTTP API. It’s fairly simple from the command line but I can’t make it work with n8n.
The following is how you will do it using CURL:
curl -X "POST" "http://influx...." \
-H 'Content-Type: text/plain; charset=utf-8' \
-d "cpu_load_short,host=server02 value=0.67"
My understanding is that body parameters in the HTTP Request accepts only pairs of key/value and it’s not possible to send RAW data, right? Is there any way I can send just a string like "cpu_load_short,host=server02 value=0.67"?
