Send whatsapp audio by Evolution in n8n
I’m trying to send a WhatsApp audio message using the HTTP Request node and the Evolution API.
According to the official Evolution documentation, the correct POST format is:
curl --request POST
–url https://{server-url}/message/sendWhatsAppAudio/{instance}
–header ‘Content-Type: application/json’
–header ‘apikey: ’
–data ‘{
“number”: “”,
“options”: {
“delay”: 123,
“presence”: “recording”,
“encoding”: true
“audioMessage”: {
“audio”: “”
In my case, I am successfully receiving the audio message on WhatsApp. However, even though the message is delivered, the HTTP Request node in n8n returns a 400 Bad Request. Also, in my case, the options object is being respected as expected — for example, I can see the “recording” status appear when the audio is being sent, and the delay is applied correctly before delivery. So it seems that both the message and options are properly processed by the API, even though it returns a 400 Bad Request.
Why is this happening if the audio is being delivered correctly? Is there something I’m missing in how n8n handles the request/response cycle?
“status”: 400,
“error”: “Bad Request”,
“response”: {
“message”: [
“AxiosError: Request failed with status code 401”
  • n8n version: 1.83.2
I created this template that sends audio, video, image and etc. using the evolution api.
This template receives an integration of the Chatwoot tool, I believe it works for you.
Among several issues trying to send WA audios, I faced the same error.
But for this one, I find my problem: the delay key was sent as string (between “ ‘ “), not as number, in JSON.
A “Bad Request” response occurs when the sent JSON isn’t quite right.
Audio key has to be in Base64… check other keys for formatting issues like the one I mentioned.
