Set node does not convert integer to string
Hi,
I am using a set node to convert a field “359” to a string, like below:
Input:
Set field:
Output:
The problem is that it outputs as an integer.
I need to force it that way:
Version on-prem: 0.233.1
Is this behavior normal?
Thanks!
Antoine
CC @giulioandreini
hi @lequeuxa
this behavior was changed in the new version of the node (now called “Edit Fields (Set)”).
The new version is more strict with types and converts numbers to strings:
You can use the new node by upgrading your n8n instance.
Let me know if that helps!
All the best
