Set-node in grey color : does not work as expected
I didn’t find this curiosity in the documentation
All my Set nodes are grey, and their set values are not in the node output at runtime
However, color is blue in the node settings
Version is 0.84.4
It looks like you deactivated the nodes. To activate them again either select them and press “d” or hover over them and then press the second button from the left (play).
Thanks jan, I didn’t know this inactive mode for nodes :dizzy_face:
