Set node missing data. Works fine when running manually
I have a multi-step data processing sequence, processing data received from a REST API.
When running the whole workflow at once, the Set Node does not output all of the field values that it is supposed to set (even though in history, these very fields that are skipped, show the relevent data in green).
When running the workflow manually/step-by-step, the Set Node works fine.
From my troubleshooting, it seems the issue is related to the Item Lists node earlier in the sequence
(in combination with the fact that the option for 'Keep Missing And Null Values" is true, and this branch of the processing is specifically dedicated to where there is a case of a Missing Value).
I’ve seen in the forums, and had to work around in other cases, issues related to either IF nodes and Set nodes, or Code nodes with Set nodes. From what I’ve seen, in those cases, they sometimes work when running the full execution, but present trouble when running manually. Here it is just the opposite.
(Identifying data has been changed for privacy considerations.)
No error message. A silent killer.
Output when running full execution:
"total_amount":"1213"
Output when running manually:
"total_amount":"1213",
"ship_to_address":"91 wallace dr brooksville, fl 34601",
"receiver_name":"bridget home services",
"supplier_email":"[email protected]",
"ship_to_name":"bridget home services",
"line_item":"reroute down spouts away from foundation, patch hole in siding, paint facia board white approx 3', remove debris away from siding"
  • n8n version: 0.233.1
  • Running n8n via (Docker, npm, n8n cloud, desktop app): npm via pm2
  • Operating system: windows server 2012
Hi @diskin :wave:
0.233.1 is an older version of n8n, and we’ve made a number of updates to nodes in that time. Can you try updating to the latest version (1.9.3), recreating your workflow to ensure you have the latest node versions, and seeing if this still happens?
