Hi, it would be great to change the Set Node UI the same way as the If node.
When mapping > 10 fields on the Set Node its hard to read, UX will improve a lot by changing the layout.
hello @greg.lopez
When you need to map 10+ fields, better to use JSON mode in the Edit Fields node or Code node ![]()
It won’t look better in UI either way ![]()
