Hi community,
has anybody been successful setting up the ai starter kit on coolify?
My goal is to start experimenting with it and later on to use supabase in the mix.
Thanks for sharing what made it work for you! ![]()
- n8n version:
- Database (default: SQLite):
- Operating system:
Hey @headset907
Does coolify support running a docker compose file or do you need to extract each part?
I’ve been using Coolify for a few months, and from what I’ve seen, you don’t necessarily need to use the starter kit. You can also create different deployments for each of the things you need. You can find various one-click installs in Coolify.
or you can copy and past the compose or you can deploy the entire repository with coolify
ATTENTION you need an hosting with GPU
thanks @mredodos!
So that’s the way you’re using it? you install each app and connect them in Docker…?
Actually, yes
@mredodos,
to connect a new app to another other app:
- do you I have to modify the docker-compose file of the stack to add any new apps?
- or just add it with the UI in the Resources or the Service Stack? (Projects > Resources > Service Stack)
Normally, you need just share the same network, and you have the specific options, or if you have custom destinations you can use the same destinations
and when you need to add the URL of some resource in an env of another resource, you can use the name of the docker container
Thanks @mredodos !
