i am creating a workflow which include the main purpose to allow me upload receipt using the n8n on form submission for several documents, with code node to capture the document information.
As the node can only handle 1 item every time, add loop over item after it.
later to pass on to Google gemini node which accept binary file to analyze the document to analyse the receipt information,item, title and output as json format, and the result json will be processed by code node, and then the parsed information will be append to google sheet for input.
question 1: I have no idea for what code should be input in the code nodes should be input, so it can generate in binary file for gemini for analyse document?
- n8n version: 1.104.1
- Database (default: SQLite):
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- Operating system: windows 11
