🛠️ Sharing My Automation Workflow: Hidemium + n8n – A Simple but Powerful Combo
Hey everyone,
Just wanted to share a lightweight automation setup I’ve been running for the past few months using Hidemium and n8n.
I’m not a developer, but this combo has helped our small team automate repetitive tasks and save a surprising amount of time.
:question:What I needed:
We work with multiple accounts across different platforms and needed to:
  • Log in daily to check orders
  • Update customer data
  • Send follow-up emails
Doing all of this manually was time-consuming and error-prone.
:white_check_mark: How I solved it:
After some testing, I ended up with a workflow like this:
  • Hidemium is used to create isolated browser profiles – one for each account. This helps avoid detection, prevents random logouts, and simulates a clean environment.
  • n8n handles the automation logic: webhook → API request → trigger Hidemium script → process result → save to Notion or Google Sheets.
A few things I really appreciate about Hidemium:
  • Smooth management of 100+ browser profiles (no crashes, no fingerprint overlaps)
  • The Prompt Script AI is super helpful — I just type “login to X and download orders” and it generates a usable script
  • Easy to call scripts via n8n using HTTP requests, making it very integration-friendly
:star2: Results:
Now I just open my n8n dashboard in the morning and hit a button.
All accounts run automatically, data gets updated, and I’ve cut down 2–3 hours of manual work per day.
Not trying to promote anything – just wanted to share in case anyone here is looking to build a simple automation stack without going full dev-mode.
If anyone’s curious, I’m happy to share a sample n8n JSON flow and my Hidemium prompt script template.
Cheers!
I’m still new to this kind of automation — would you say it’s beginner-friendly, or do I need some scripting knowledge to start?
Yes, it’s beginner-friendly — Hidemium’s Prompt Script AI lets you automate tasks just by describing them in plain text. No coding required.
Combined with n8n’s visual workflow builder, it’s a very accessible setup even if you’re new to automation.
Let me know if you’d like a basic starter template!
Been thinking of switching to Hidemium for multi-account work. This combo with n8n looks like a game-changer. Thanks for sharing!
can you share it?
