When I attempt to sign up for n8n.cloud using my @yahoo.com email address, I never get the confirmation email. I’ve tried to do “forgot my password”/“reset”, but never get the email.
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
n8n version:
Database you’re using (default: SQLite):
Running n8n with the execution process [own(default), main]:
Running n8n via [Docker, npm, n8n.cloud, desktop app]:
Yes, Discourse will use a separate server from n8n.cloud, so this would explain why might see a different behaviour there. We can change your n8n.cloud email later, simply reach out via the n8n.cloud Help center once you have signed up.
