You can easily build a simple randomizer node using Functions Node & IF Node.
Function Node generate a random number between 0-6\
If the number is smaller than 3 It’ll be True else it will be false.
Number | |
0 | |
1 | |
2 | |
3 | This is the center number between 0-6 |
4 | |
5 | |
6 |
Workflow Code:
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
350,
350
"parameters": {
"functionCode": "items[0].json.RandomNumber = Math.floor(Math.random() * 7);\nreturn items;"
"name": "Function",
"typeVersion": 1,
"position": [
550,
350
"parameters": {
"conditions": {
"number": [
"value1": "={{$node[\"Function\"].json[\"RandomNumber\"]}}",
"value2": 3
"name": "IF",
"type": "n8n-nodes-base.if",
"typeVersion": 1,
"position": [
750,
350
"parameters": {},
"name": "NoOp",
"type": "n8n-nodes-base.noOp",
"typeVersion": 1,
"position": [
950,
250
"parameters": {},
"name": "NoOp1",
"typeVersion": 1,
"position": [
950,
440
"connections": {
"Start": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"node": "IF",
"type": "main",
"index": 0
"IF": {
"main": [
"node": "NoOp",
"type": "main",
"index": 0
"node": "NoOp1",
"type": "main",
"index": 0
