Hi There,
I am trying to add a Toggle Heading 1 block with text to a Notion page. After a lot of trial and error I figured out how to do it, but it seems very convoluted as though there should be simpler way.
Is there a simpler way to accomplish what I have below? I’m doing this in the cloud.
Thanks!
Dan
n8n
April 6, 2024, 4:03am
2
n8n version:
Database (default: SQLite):
Operating system:
@Dan_Irwin Did you figure this out? Running into this as well.
I didn’t figure out a simpler way in the end. Just moved that into a subflow so it didn’t seem so messy.
Got it. Seems to me n8n can add support for this using the is_toggleable
parameter to Heading blocks, since that’s now available in the API.
Yeah, that’s what I was wondering too.
I’m new to the Notion API. Was it not always an option?
I’ve been in and out of Notion, but I don’t remember seeing that previously. Could be wrong.
system
Closed
July 17, 2024, 4:21am
8
