Hi everyone, I created this workflow but as you can see it is divided into 2 flows, I would like to simplify it into a single flow if it were possible but the problem is that I don’t know how to recall the webhook data in the subsequent ones operations depending on which of the 2 is activated. Can someone help me?
- n8n version:
- Database (default: SQLite):
- Operating system:
@IvanLao , you can introduce a querystring into your Webhook URL. That is, instead of the external application triggering the workflow with two different URL in the format http://N8N_DOMAIN/webhook/ID
for each of the two scenarios, the URL to GET
would be the same one but with a different querystrings (that is only one webhook). Something like below:
http://N8N_DOMAIN/webhook/ID?flow=inserito
http://N8N_DOMAIN/webhook/ID?flow=aggiornato
Then, based on the the value of flow
you would act appropriately.
