Slack authentication issue
Hi,
While integrating with slack i am not able to give redirect url as
http://localhost:5678/rest/oauth2-credential/callback
Please let me know how to proceed
Hey @Gauthami_Viswanathan!
Are you running n8n locally? If so, you would have to start n8n with the tunnel using the command use ngrok to get an https URL. You will also have to the Webhook Tunnel URL environment variable Environment Variables | Docs).
I’m facing the same issue. Is there any Update .
Please create new topics for your issue, don’t revive 4 year old topics. Too many things have changed since then.
