Small visual bug in custom nodes customization section
I want to upgrade my custom node to the new version. In the process I noticed a small problem. The outline button type is used, although I expect to see a standard button.
screen
After examining the code a bit, I found out that for some reason the outline button type is used in the template. In my opinion, the lettering should be orange. Or the button itself should be orange.
I hope to fix it in the next versions of the application. Thanks.
  • **n8n version:1.20.0
  • **Database (default: SQLite):SQLite
  • **n8n EXECUTIONS_PROCESS setting (default: own, main):main
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):npm
  • **Operating system:Windows
Hey @yatolstoy,
Thanks for reporting this, I have created an internal ticket which we will be tracking as PAY-1272
