Editor is now accessible via: http://localhost:5678/
ERROR RESPONSE
ResponseError: There is a problem with your SMTP setup! Connection timeout
at /usr/local/lib/node_modules/n8n/dist/src/UserManagement/routes/users.js:53:23
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async /usr/local/lib/node_modules/n8n/dist/src/ResponseHelper.js:90:26 {
httpStatusCode: 500
A connection timeout normally indicates some kind of network issue, Is there any firewall rule in the way maybe? It could also be wort trying the TLS option or the 2465 port that is offered to see if that changes anything.
