I try to activate SMTP with N8N deploy through Portainer (stack).
Here is the stack used :
version: '3.8'
services:
postgres_n8n:
image: postgres:latest
container_name: postgres_n8n
restart: always
environment:
POSTGRES_USER : user
POSTGRES_PASSWORD: pass
POSTGRES_BD: n8n
PGDATA: /var/lib/postgresql/data/pgdata
TZ : Europe/Brussels
ports:
- 5435:5432
volumes:
- /n8n/db/db_storage:/var/lib/postgresql/data
networks:
- mynet
n8n:
image: n8nio/n8n:latest
container_name: n8n
stdin_open: true
tty: true
user: user
restart: always
environment:
- "DEBUG=true"
- "DB_TYPE=postgresdb"
- "DB_POSTGRESDB_HOST=192.168.0.11"
- "DB_POSTGRESDB_PORT=5435"
- "DB_POSTGRESDB_DATABASE=n8n"
- "DB_POSTGRESDB_USER=user"
- "DB_POSTGRESDB_PASSWORD=pass"
- "N8N_SECURE_COOKIE=true"
# Config SMTP
- "N8N_EMAIL_MODE=smtp"
- "N8N_SMTP_HOST=ex4.mail.ovh.net"
- "N8N_SMTP_PORT=587"
- "N8N_SMTP_SSL=false"
- "[email protected]"
- "N8N_SMTP_PASS=pass"
volumes:
- /n8n/n8n_storage/:/home/node/.n8n/
- /certs:/certs
labels:
- "traefik.enable=true"
- "traefik.http.routers.n8n.rule=Host(`n8n.mydomain.com`)"
- "traefik.http.routers.n8n.entrypoints=websecure"
- "traefik.http.routers.n8n.tls.certresolver=myRes"
networks:
- mynet
networks:
mynet:
external: true
The error I receive within the container log:
ValidationError: The 'X-Forwarded-For' header is set but the Express 'trust proxy' setting is false (default). This could indicate a misconfiguration which would prevent express-rate-limit from accurately identifying users. See https://express-rate-limit.github.io/ERR_ERL_UNEXPECTED_X_FORWARDED_FOR/ for more information.
23
at Object.xForwardedForHeader (/usr/local/lib/node_modules/n8n/node_modules/express-rate-limit/dist/index.cjs:166:13)
24
at Object.wrappedValidations.<computed> [as xForwardedForHeader] (/usr/local/lib/node_modules/n8n/node_modules/express-rate-limit/dist/index.cjs:338:22)
25
at Object.keyGenerator (/usr/local/lib/node_modules/n8n/node_modules/express-rate-limit/dist/index.cjs:593:20)
26
at /usr/local/lib/node_modules/n8n/node_modules/express-rate-limit/dist/index.cjs:644:32
27
at /usr/local/lib/node_modules/n8n/node_modules/express-rate-limit/dist/index.cjs:625:5 {
28
code: 'ERR_ERL_UNEXPECTED_X_FORWARDED_FOR',
29
help: 'https://express-rate-limit.github.io/ERR_ERL_UNEXPECTED_X_FORWARDED_FOR/'
- n8n version: n8n:latest
- Database (default: SQLite): postgre
- Running n8n via (Docker, npm, n8n cloud, desktop app): portainer/docker
- Operating system: Debian
