Some Active campaing custom fields not showing
I have a lot of custom fields on my active campaing and some of these fields don’t appears in the n8n add contact node. Custom fields in Active Campaign:
Some fields shows, after the UF-75 don’t appear anymore:
Someone knows why this error happens?
There’s no error message.
  • **n8n version:1.89.2
  • **Database (default: SQLite):default
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):Docker with easypanel
  • **Operating system:Ubuntu
Does clicking the three dots next to the “fixed|expression” selector, then click refresh, work?
Otherwise you may have to insert them manually with the Expression option.
We encountered similar issues with notion fields not appearing, but inserting them manually still worked fine.
Thank you for answer!
I’ve tried your suggestion to refresh the list but didn’t worked.
I’ll try the second, insert manually with expressions. Do you have a tutorial of how to made it?
You would just use expression mode, and put the field name in like:
{{ "fieldnamehere" }}
