Split an Array keep sub array keys as labels
I have an item that contains an array I would like to split down. Each of the array items has a unique name that represents what the contents of the array are, in this case the results of the last 30 days of my email protection report.
Using the split node on the inbound array does indeed split it down as needed, however I lose the headers in each of the arrays, which I need as labels.
Any assistance would be appreciated.
Before
"accountId": "######",
"type": "email",
"period": "24h",
"count": "30",
"inbound": {
"allowed:none:_total": {
"2024-04-18T00:00:00+0000": 26,
"2024-04-19T00:00:00+0000": 21,
"2024-04-20T00:00:00+0000": 10,
"2024-04-21T00:00:00+0000": 8,
"2024-04-22T00:00:00+0000": 138,
"2024-04-23T00:00:00+0000": 53,
"2024-04-24T00:00:00+0000": 29,
"2024-04-25T00:00:00+0000": 40
"allowed:none:none": {
After
"accountId": ""######",",
"type": "email",
"period": "24h",
"count": "30",
"outbound": {
"inbound": {
"type": "email",
"period": "24h",
"count": "30",
"outbound": {
"inbound": {
  • n8n version:1.38.1
  • Running n8n via Docker
  • Operating system: Win 11 via WSL
Hey @PsychoAlex ,
Fields To Include in Split Out node doesn’t work for you?
hello @PsychoAlex
What is the point to split it?
You don’t have an array there, its an object with nested objects. But you can do that with code node
It does not, sadly. The API only returns an object if it contains any data, and some of them are quire rare. The object name is also a concatenation of 3 separate fields, Action:Threat:Reason, so it the number of different permutations is rather large.
Fantastic, thanks. Been trying to manage it in JS, but my JS is rather rusty to say the least.
I need to separate it out to make the reporting much easier, now I can parse each object as a separate item, rather than having to write the logic to process the entire set as one dataset.
