Split and handling null
With the help of this forum and some logic, I performed data transformations (serializing items and replacing strings). However, I’m stuck with splitting strings from a key and inserting the split indices back into their respective object. (refer to “Expected JSON”)
Data transformation node
const serialItems = [];
for (const element of items[0].json) {
  serialItems.push({json: { ...element, COUNT: element.COUNT.replace('+', '').replace('-', '')}});
return serialItems;
Split logic tried
let splitItems = [];
for (item of items) {
  myValues.push(...item.json.ToSplit.split(' '));
return myValues.map(e => {
  return {
    json: {
      key: e.trim()
Please share the workflow
mock data and logic node
Input mock JSON
"COUNT": "+1-1",
"KEY1": "Example1",
"ToSplit": "Test A"
"COUNT": "+2-1",
"KEY1": "Example2",
"ToSplit": "Test B"
"COUNT": "+3-1",
"KEY1": "Example3",
"ToSplit": null
Output JSON
"COUNT": "11",
"KEY1": "Example1",
"ToSplit": "Test A"
"COUNT": "21",
"KEY1": "Example2",
"ToSplit": "Test B"
"COUNT": "31",
"KEY1": "Example3",
"ToSplit": null
Expected JSON
"COUNT": "11",
"KEY1": "Example1",
"ToSplit": "Test A",
"Split_value_1": "Test",
"Split_value_2": "A"
"COUNT": "21",
"KEY1": "Example2",
"ToSplit": "Test B",
"Split_value_2": "B"
"COUNT": "31",
"KEY1": "Example3",
"ToSplit": null,
"Split_value_1": "", //assuming inserting empty strings is recommended
"Split_value_2": ""
The output returned by the split logic above will make a new object of every split value, thereby doubling the no. of items, which is undesired, as we want to insert split values into their respective object itself.
Thank you for your time and valuable pointers!
If you are OK with just an array of the split values, instead of keys you can use this in you second function:
// Split field ToSplit into array
for (item of serialItems) {
  item.json.split = item.json.ToSplit?.split(' ') || []
return serialItems;
Which would give you
    "COUNT": "11",
    "KEY1": "Example1",
    "split": [
      "Test",
      "A"
    "COUNT": "21",
    "KEY1": "Example2",
    "split": [
      "Test",
      "B"
    "COUNT": "31",
    "KEY1": "Example3",
    "ToSplit": null,
    "split": []
Snippets like these help me understand more about JSON and n8n on the fly. Thank you very much!
