Split in batches execution order
hi, assume using split in batches node, and i have 2 items as input and batch size is 1.
While running; does it wait for the execution of first item to finish before starting the second one, or are they are run in parallel ?
If in parallel, is there an easy solution for it to wait ?
tnx
  • n8n version: 1.8.2
  • Database (default: SQLite): postgresql
  • Operating system: Mac OS Ventura 13.5.2
hello @slenderwrist
They will be executed sequentially (one-by-one) like in any Loop. So yes, it waits when the first item will be processed.
Hi @slenderwrist
A quick note to highlight that n8n processes each item in the node’s input individually, so it is already looping items by default. For the most basic cases, you don’t even need to use the Loop node.
You can find more info here: Looping | n8n Docs
Hope it helps!
