Split In Batches node Error
When run Split In Batches as node i get below error , but when run the whole workflow it’s working fine.
Problem executing workflow
There might not be enough memory to finish the execution. Tips for avoiding this here
  • n8n version:0.277.1
  • Operating system:Ubunto
Hey @hasanm,
Can you share the workflow or a simplified version that reproduces the issue?
