I am getting POC data from apollo which I need to do some mapping with . Apollo does not give the entire data at once but divides into pages and hence make separate request for every page. Each page has 30 entries . I want to loop through the 30 entries one by one and do some operation (here I simply appened in google sheet since actual workflow is very long). After the 30 entries is completed I would go and fetch the next page of 30 entries.
The problem is Split in Batches node works fine for the first iteration(page of 30 entries ) , but in upcoming iteration it does not loop and directly goes to the done branch. Is there any way to fix it or any other alternative ?
Hi @Shiv_Jyoti_Garai, it seems you have two overlapping loops here (your Google Sheets node connects back to the Split in Batches input as well as does your Wait node via a couple of other nodes). From looking at this I am not quite sure what exactly you would be expecting in such a workflow.
I am not familiar with apollo, but it seems their API supports pagination which means you wouldn’t need Split in Batches. Perhaps you want to try and build a simpler loop without the Split in Batches node? Like so for example:
