Split in Batches - only running 6 times?
I’m trying to get a list of accounts, and then a list of contacts for each account.
I need to use Split in Batches otherwise I get errors… The problem is Split in Batches is only running 6 times, even though the input is 23 account. any ideas? (it’s running in batches of 1).
Probably related, I have an IF node checking if the cycle is complete, and it never goes to true.
Here’s a screenshot so you can see the input counts:
Please share the workflow
  • n8n version: 0.209.3
  • Database you’re using (default: SQLite):
  • Running n8n with the execution process [own(default), main]:
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
And I figured it out…
BMS_GetContacts was returning an account with no contacts, so it was stopping. I inserted an IF node to handle, and all is good!
