Split in batches "RunIndex"
Run index of split in batches isn’t working properly :
Here’s the config of the condition rule :
It should goes to the True branch in the second execution, can you figure out why ?
$runIndex returns a number and not a string. So if you update the IF-Node to compare numbers it will work fine.
