Split Out Error - this.getNodeParameter(...).split is not a function
Hello everyone, it’s only been a few hours since I discovered N8N, already installed and already discovering the tool, and of course the first questions :slight_smile:
I’m trying to split out Basic JSON, but there’s no way I can make it work.
Am I missing something on this ?
Thank you !
TypeError: this.getNodeParameter(…).split is not a function at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Transform/SplitOut/SplitOut.node.js:112:18) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:722:42) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:711:66 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1141:20
  • n8n version: 1.61.0 (Self Hosted)
  • Database : SQLite
  • n8n EXECUTIONS_PROCESS setting : own, main
Welcome to the community @TheGlitch !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
The field to split out is just “topics”. No need to use an expression in this case.
Thank you very much ! Works like a charm :slight_smile:
