I have a workflow in which I have split out an API response in to individual items. I am then calling another API for each of the individual items. The response looks like this:
"totalCount":1,
"hasMore":false,
"firstIndex":0,
"list":[
"id":"009c84bb-0c55-4dcd-b639-dd7a627e7da7",
"name":"Plaza BDC"
"totalCount":1,
"hasMore":false,
"firstIndex":0,
"list":[
"id":"6f00f5d5-5b0e-4127-9075-9522681a0d3a",
"name":"Battersea"
"totalCount":1,
"hasMore":false,
"firstIndex":0,
"list":[
"id":"d158a688-9b64-4186-ae78-18d42a8103fe",
"name":"StJamesSquare"
"totalCount":2,
"hasMore":false,
"firstIndex":0,
"list":[
"id":"101f4571-2465-4e31-ab42-ed0cefbe2fd7",
"name":"Edinburgh"
"id":"a89b0ed4-5206-4cc9-8298-d982ebb7bf92",
"name":"Minster Building"
"totalCount":1,
"hasMore":false,
"firstIndex":0,
"list":[
"id":"7bc0e0fe-c7e5-4312-95bc-28a38b487fb8",
"name":"Alexandra Surgery"
"totalCount":12,
"hasMore":false,
"firstIndex":0,
"list":[
"id":"6743be74-11ce-4945-baa6-6d5562a837fc",
"name":"Reference Point"
"id":"4ce6ef1b-4ac8-4a68-8ae6-2790b2512003",
"name":"Central 1st Flr"
"id":"11efa3f4-b0a6-44f2-99a8-865e40b656bf",
"name":"Ikoyi"
"id":"346c4ba2-2eba-4d16-8a79-0c9fdee130ae",
"name":"Health Spa"
"id":"bc6d2c09-b697-4543-bf3d-5024b9587684",
"name":"Exhibition Space"
"id":"11421c95-c395-4931-ad0d-12bc937fa2b8",
"name":"7th Floor"
"id":"bb069b7b-af01-4a0c-a265-cc5e009aa9e2",
"name":"Surrey 2nd Floor"
"id":"2027d6c7-e149-461d-8e0b-3d74e867ae6e",
"name":"Arundel 1st Flr"
"id":"d2f2a8d4-e75b-496f-b0d0-7fb521c69f1e",
"name":"1st floor Surrey"
"id":"7bcbcfd7-8a54-4726-aed3-95fb30402f68",
"name":"6th Floor"
"id":"144ca431-0dd8-438e-8668-ebed56e2e7aa",
"name":"Lower Ground 2"
"id":"6bd55dc1-f9cf-4ff2-bad6-5b46872190f2",
"name":"8th Floor"
As you can see, each object in the parent array contains it’s own array called ‘list’. I want to use each of these lists individually in my next step. How do I split out from here so I can run the next step once for each of these lists?
Thanks in advance,
Jonathan
Please share the workflow
- n8n version: Azure AKS Latest Version
- Database you’re using (default: SQLite): Postgres
- Running n8n with the execution process [own(default), main]: Not sure what this means
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Azure AKS / Kubernetes
