I am trying to Connect SQL Server with N8N SQL Node but am unable to establish a connection
Failed to connect to EC2AMAZ-A1DBF71:1433 - getaddrinfo EAI_AGAIN EC2AMAZ-A1DBF71
tried multiple times but still failed to connect anyone can suggest what to do this in this case.
Jon
3
Hey @chandan988,
I suspect the issue with the hostname looking at that, Can you try the IP or the full fqdn if it is a record that can be resolved.
system
Closed
4
