I try to set up an SQL Agent with an SSH tunneled connection. While connections with the same parameters work fine from MySQL Workbench, the agent returns an error message, when issuing a chat message to it. Though the connection tests run upon saving are successful.
Stack trace:
Error: connect ECONNREFUSED ::1:3306 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1611:16)
See error message
- n8n version:
1.78.1 (Self Hosted) - Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: MacOS 15.1.1
