I am trying to connect via ssh to a windows, so that it executes a .bat
But, it does not make the connection and this message is displayed.
But, if I connect from my windows to the ssh, it connects me without any problem.
SSH connection failed: Timed out while waiting for handshake
- n8n version:
- **Database (default: SQLite):**SQLite
- **n8n EXECUTIONS_PROCESS setting (default: own, main):**Own
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**Docker
- Operating system: Ubuntu 22
n8n
2
- n8n version:
- Database (default: SQLite):
- Operating system:
Jon
4
Hey @diaverso
I can’t tell from your screenshots but are you trying to use localhost / 127.0.0.1 as the host url from the container?
This is the information that I get from the docker, connecting via remote desktop, if everything works perfectly.
When I enter the server ip, or try with the ip indicated in the portainer, I get the handshake error.
I think, because of some problem. It is not saving the handshake in n8n.
new error:
“errorMessage”: “All configured authentication methods failed”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “1.72.1 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“Error: All configured authentication methods failed”,
" at doNextAuth (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:865:21)“,
" at tryNextAuth (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:1082:7)”,
" at USERAUTH_FAILURE (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:430:11)“,
" at 51 (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/handlers.misc.js:408:16)”,
" at Protocol.onPayload (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/Protocol.js:2059:10)“,
" at AESGCMDecipherNative.decrypt (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/crypto.js:987:26)”,
" at Protocol.parsePacket [as _parse] (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/Protocol.js:2028:25)“,
" at Protocol.parse (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/Protocol.js:313:16)”,
" at Socket. (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:775:21)“,
" at Socket.emit (node:events:519:28)”
Jon
8
This error would suggest the ssh server is not accepting the authentication method we are using with n8n.
Did you update it to use key based auth but are still trying username and password?
system
Closed
9
