Hi,
I’m trying to get data via HTTP GET Request from an https website. The http request node doesn’t return data without “Ignore SSL Issues” option. How can I connect to the site with https?
n8n.io works in a docker container.
Hi,
It does still make the request via https even if you activate that setting. It “just” means that it is not secure as probably something is wrong with the SSL certificate or the way it got set up on the server.
So the problem is not n8n, the problem is the server you request the data from. So you should probably contact the admin of the server to fix the issue.
You can check here if it finds the issue:
https://www.digicert.com/help/
