Leon van Zyl writes:
In this n8n AI Agent tutorial you will learn how to create a RAG Chatbot that can answer questions from your own knowledge base.
We will also embed the chatbot into a website using the n8n web embed script.
Excellent work, Leon. Do you have any tutorial on better managing knowledge data? For example, how to ensure that when a document in Drive is modified, the vector database is automatically updated? Or when a document is deleted, it is also removed from the vector database?
Best regards!
Thank you very much. Im newbie and it so helpful with me <3
Thank you for this, but I built according to instructions, and it is not working:
Thank you for this! My first successful (sorta) RAG!
Appreciate if you could help with some questions and issues I have. I did everything as per the video but still got strange responses.
I put in some company SOPs in a table format in Google Docs, it failed to read the data.
Then I made them into paragraph format, and it manages to read and return data.
After a while, it makes its own answers.. For example, first time I asked it how to prepare a Costing Sheet, it churned out a good response as per our SOP. Second time I asked, it returned a generic ChatGPT answer that deviated from our SOP.
Not sure why this happened.. Then when I put public URL, the answers became totally deviated from the SOP and it answered as generic ChatGPT…
Pretty stuck at this point cos I didn’t get any error messages.
